Help Power Button Is Faulty - Can I Fix It...?
Hi All,
My Wildfire S power button is only working every so often and usually only when I press quite hard.
Was wondering if anyone has used a t5 screwdriver to get to the power button and fix it.
If you have - I would much appreciate some advice as I'm thinking of taking the back plate off to see if I can do anything to make the power button more responsive.
What do you reckon?
Cheers in advance.
(BTW - I know I can get an app to use other buttons to wake the phone up but I'd rather try to fix the button itself)
