When I long press the power button on an Xperia D2005, it shows a menu with 6 options but on a Nexus5 it only has 1 option "Power off".
Is there a way to have more options on the Nexus5?
Yup, root the device, install Xposed and then install the APM+ module for that. It allows you a wide choice of actions for the Power menu, including various shutdown/reboot options and screenshot capture.
n.b. there are very likely other equally good options, but the one suggested above is what I use myself.
