dazzle_rsa
Hi all
Long story short (ish), my Wife left her S2 in her pocket and it ended up in the washing machine. I took it out and dried it, and put it in a bag of rice for a week.
I switches on and boots up!!!!
Problems are, it doesn't pick up the sim card, the screen time-out and switches off but then switches itself back on and off the whole time.
The strangest problem is the power button, it doesn't work when i have booted the OS, BUT.... if i pull the Batt and put it back in the phone doesn't switch on automatically, so i press the power button and it immediately switches on the phone, so the physical button is working!
This is leading me to believe that there is now a severe software problem, so i want to reload the rom and see if it helps.
But, the usb wont pick it up for odin to flash, and when i boot into recovery, the power button stops working to select sd card install.
Anyone got any suggestions, i really dont want to throw the phone away, and cant get a new one for the next 2 years....
thanks in advance...
