Help Power off app
DroidRick
I thought about the Apps section, but I'm looking for something specific to the SGS. I know there are a ton of apps that allow you to add a home widget to 'power off' your SGS (turn off the screen). Are there any apps that completely turn off the SGS, as if you pressed the power button on the right side and selected Power Off? A complete power down? So you press a widget and it completely shuts down your SGS? Any apps out there? TIA
I don't know of a widget but I know of an app Quick Boot that has options to Reboot, Recovery, and Power off, you can create a shortcut for Power off on the home screen and just pressing the short cut will shutdown the system. The only thing is that you need to be rooted to use the App.
... I know of an app Quick Boot that has options to Reboot, Recovery, and Power off ..... The only thing is that you need to be rooted to use the App.
Thanks for your help! It's too bad but I'm not rooted. :( If anyone else knows of something I'd appreciate hearing about it.
