Power on Problems
alok25935
Hello i have power on problem in my pad.....It just shows
SWVer=3.16R
MODEL:FM6-0001
HWVer:106
Power on with pressing VOLUME_DOWN keys to leave Auto-FTM.
PLEASE HELP ME.....
Hello and welcome to Android Forums! :)
I found a few references to that issue and apparently you had the vol. down button pressed while powering on which put it into FTM (Field testing mode). Since I don't have any expereince directly with that tablet, all I was able to find was that to put it back into normal mode, you have to press the reset button.
Generally speaking a reset button on a tablet will be a small hole on the back or side that you press with a small wire like a paper clip. Be advised that a microphone might also be a small hole so don't go poking around unless you are certain.
you may want to ask in General Tablet Talk - Android Forums to see if anyone has any direct experience with your model.
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
