cool.gautam
Hey all i know there must be some power saving tips in different threads and different places which really freaks out a newbie so here's a list of recommendations i use that may help someone :
1 ) Brightness Adjustment - Simple way is to manually adjust the brightness, such as in dark places you can lower the brightness and in daily home usage a bit normal and in outdoors u can increase it . In nutshell don't just put always ur brightness to full which drains out battery a lot.
2 ) Live Wallpapers -Yes , we all know that . They are undoubtedly magnificant but are the largest eaters i would say of our battery. So better turn em off .
3 ) Connectivity - When not needed, GPS, WiFi, Bluetooth just turn em off . Morover even Edge / Gprs connections consume battery but not as much as wifi and bluetooth and GPS so better turn all of em off when not needed.
4 ) Turn Off the Sync - Synchronize is kind of thing, in the background of the A70 which eats loads of battery. If you want to use it use Sync manually after 1-2 days or according to your needs. Don't just set it to automatic BATTERY EATER
5 ) Switch better SD card - Sometimes running and reading speed depends entirely on your memory card, as far as possible with a good card. i would recommend a class 10 memory card .
If you are not using my ROM's or any other 6 and 7 are needed but if you are YOU DON't need em [ They( custom rom's ) have autokill freq. and CPU adjustments inbuilt ATLEAST in my ROM don't know of others ]
6 ) CPU freq. ( Rooted users ) - If you are Rooted try the SetCPU like overclocking software ( not in our case ) . But I want to say is that this software is used to lower frequency of CPU when its not needed like when screen is turned off and charging sometimes...Do u need 600mHz or just 200mHz / Or any other lower freq. ? People can set it according to their needs.
7 ) Task Killers - I ' m not promoting or demoting them....I don't know some people say its bad for phone but it seemingly Increases your battery perfomance . It actually closes the app which remains running in the background letting u to better battery life.
These are the basic tweaks or tips u can say which will enhance your battery life . These are not advanced tips , its just for beginners . If you want more u can seek scripts , Apps , and much more.
