Please help
I am in a dilemma on what to do with my S3 it only last for a day and if i'm luck it last for 2. how can i improve my battery performance?i have already tried the other options that Google has provided me with but i am curious on the topic that some users used a battery saving app for the S3 but the problem is is it safe to use a battery saving app when the S3 comes already with a power saving option and if installed with a battery saving app can it go hand in hand or work simultaneously with the power saving app?
please help me on what should i do or recommend me if i should install a battery app and what battery app is good to use with the S3
thank you
thank you
