How do I power up in bootloader, not recovery? I want to flash a splash screen. I used to have that option in the power menu in my HTC. Is there a way to put it in my Spectrum (CM 10.1) power menu?
Even with an unlocked bootloader?
I thought fastboot/HBoot was an HTC thing....?
I just drop my boot animation in the system/media folder but there is no way to change the splash screen without powering up in bootloader which we can't.
The splash screen is inside the ramdisk image of your kernel. If you want to edit it, that is where you need to look, but you'll need to convert it to RLE format.I just drop my boot animation in the system/media folder but there is no way to change the splash screen without powering up in bootloader which we can't.
Thanks ortrigger!!! I will try it tomorrow.
