Root Poweramp Losing Library
EHokie
I'm putting this in ATR because I think it relates to CM10 somehow, but sporadically (usually two or three times a day), Poweramp loses its library for me and has to be rescanned. Anyone else have this issue or any suggestions?
Put all your music in one folder and have it only detect that folder.
That happened to me too, but after doing this (^) it stopped doing it.
It'll also scan your folder faster. I read somewhere that PAmp scans like 2000 files per second or something... so cutting down how many folders it scans will definitely help with the waiting (scanning) time.
i had the same issue. the easiest way to fix it (imho) is to go to settings, folders and library, then its somewhere like folder scanning or something similar. then uncheck auto scan. just remember that when you add new music to manually scan if it doesnt pick it up
