beats audio adds +3 DB peaks to the lows, and highs, and scoops the mids by -1 DB.
The thing is that it adds a very large amount of distortion to the signal. Basically, you're actually decreasing the overall audio quality by distorting the sound.
If you honestly want to use this phone as a portable music player, drop between 50-200 hz by about 1~2 db, and raise the mids by about +1 db at most. Leave the highs where they are.
Can you screenshot an ideal EQ setup on PAmp?
Ideal is subjective to your ears and your headphones. I know what you mean, cause sometimes getting settings PERFECT (I'm OCD to begin with) is what I want, but you ultimately just have to play around and find what you like.
Buy Klipsch S4A II's and leave EQ where it is
I raise the highs past half way and bump the lows up about half way I put the mids down a few notches lower. The treble and bass I put at about half way/a little past half way.
Untouched EQ is unfathomable to me :O
