prBoomX - Doom for the X and other newer devices
Hey all!
ClarkDawg of prboom4android - Project Hosting on Google Code (or Doom4Android from awhile back)
Made a working Doom emulator that uses Freedoom (other wads can be applied, just not downloaded from the app). Unfortunately the version supplied on the project site has no way of shooting, strafing, etc, with touch only devices.
I downloaded the source yesterday and have successfully added controls to the app, so now it IS playable!
Install Instructions:
- Download App
- Click Install Wad's (if it errors, hit cleanup, then quit and re-open, then try again)
- Click Install Sounds (leave, re-open)
- Check Fullscreen (or not)
- Check Virtual DPad (will activate dpad and buttons)
Changelog:
1.1 Beta - Built off of 1.0Beta of prBoom4Android
- Has fire, use, strafe, enter, options and map buttons
- Strafe is a modifier, mean click it to turn on, and click to turn off
1.2 Alpha - Built off of 1.0Beta of prBoom4Android
- Has multi-touch controls!
- Higher resolution (640 x 400)
Known Issues:
- Kinda laggy at new res
- Controls are pretttty sensitive
prBoomX 1.2 Alpha
Non-Fullscreen Screenshot:
Questions/Comments?
twitter/gmail: phimuskapsi
Site:
GO TO SITE!
APK:
GRAB APK
