Preexisting mobi files to Kindle library?
PrinceCorwin
Android Expert
Just got a KFHD. Is there a way to add my Preexisting mobi books to my Kindle library so I can read them on all my devices?
Sent from my DROID RAZR HD using Tapatalk 2
Tried that. Didn't work. When I long press on mobi file and choose share, I don't get an option of sending to kindle.
You're right ... you've to share your .mobi files one at a time for to send to Kindle.
1 Open ES and search your .mobi files.
2 Have a long press on one of your .mobi files ... all files will get a check box.
3 Tick the check boxes of one of your other .mobi files.
4 Use the option More ... a menu will pop up.
5 Use the option Share ... a menu will pop up.
6 Use the option "Amazon Send To Kindle".
Sorry for misleading.
Thanks txrose, especially for the "one file at a time" hint :)
Harry
