Help Prevent Play Music from using censored versions?
OhSeven
I know you can "fix incorrect match" for any unwanted censored songs, but it's very inconvenient to find and fix the problems one song at a time at home. I only uploaded a small part of my library, but after a few months of regular use I'm still coming across censored songs and it's rather annoying.
I want to upload more of my library, and would also reupload what I have now if I don't have to deal with the problem anymore. Is there an easy solution yet?
Is this songs that the record companies have marked as "Parental advisory. Explicit lyrics" why it's censoring them? Is the a setting in Play Music to turn it off? I don't use it myself, because it's usually unavailable.
I too have faced this problem with some of my music that ive uploaded recently. I don't like it. I thought I was going crazy before you posted this though :D
The problem is when uploading music. Google tries to recognize the song and if there's a match, it will use its own file instead of user uploads. Sometimes though it will mistakenly match the censored version. It's hit or miss especially with more popular music.
I'm guessing there's no easy solution. The fix is to mark each song as an incorrect match and it will force the upload of your own file. The annoying thing is it must be done on a desktop and each song takes 2 precise clicks and 2 keypresses to dismiss prompts in a laggy web interface
