Gorlash
I've shut down all the background apps that I don't use, and generally I get 3 to 4 days between charges (phone turned on all the time, but only actively used for a few minutes per day).
However, I have a problem when I go out of town to go hiking. In the area where I hike, I typically lose the connections entirely - no phone, no data. When this happens, the phone (ZTE N9120 Avid 4G) seems to go into a hyper-search mode, and it typically drains the battery to 0 in about 3 HOURS !!!
I've started manually putting the phone in airplane mode if I know I'm going to such an area, but I would really like an app that would intelligently handle the search, as in "If I lose signal, and can't get it back after 5 minutes of trying, go into airplane mode for 15 minutes, then try again. Rinse and repeat.".
I don't want the app to do anything else, like turning things on and off generally, I just want to manage this no-signal situation.
Is there any app that will do this?? I've looked at GreenPower and JuiceDefender, and Advanced Mobile Care; they all do alot of other things, but they don't appear to actually address this specific issue.
