Phases
NO LONGER ADMIN
You should see previous and next links in the PM system now, similar to what you would see at the bottom of a thread. I've put it above the quick reply in this case though, as I find it a better fit in that position.
Edit: I've also added "reply to all" feature. When you get a PM that has been sent to multiple people, you will see "reply to all" by the list of recipients, as well as a note in the quick reply section reminding you that the quick reply will only go to the sender.
I enabled this once before, but there was a nasty "bug" of the quick reply sending to all by default, which could have lead to some disastrous results. I would rather people have to consciously click a "reply to all" button first.
Thanks
Thanks
