Help Prime + Dual Shock
I am wanting to connect a ps3 controller but do not have a dock. Is this possible? If so what is the best way to get some mario 64 going on this beast.
Thanks
much easier with the dock. you can connect a ps3 cotroller over bluetooth using the sixaxis program from the market but your prime needs to be rooted to do this.
either that or you need one of the adapters that turns the propriety port on the prime into a usb. Good luck finding one of these though, apparently they are pretty hard to come by.
