Prime turning to crap
First, off I randomly got the green screen for the back camera. Half of the apps are force close or freeze. Finally, the tablet is slow as molasses even on high performance.
Does anyone have with their primes?
Although I do not own your device, I am curious as to whether you have tried to do a factory reset to fix these issues. Sometimes that helps to smooth things over and get everything working well again.
I had same experience with camera showing green image after one of firmware update.
The resolution was contact Asus support and have the tablet fixed by them.
