Hi thanks for the reply, but there are no ... or star at the top, all there is is an option to move it to a save folder, even from there you can not print
If it's the normal Samsung email app, there should be ... Next to the star in the email header when the email is viewed ( not the ... in the top right corner)
Hi, there is no option to shareMaybe you have to select it through the share menu?
