Print application?
Smudgie
I would like to have the ability to print documents (docs to go), texts, ect directly from my phone. I am guessing that if such an app exists I would have to have a WiFi capable printer? Is there an app to do this? If so what do I need to have once installing this app? Thanks a bunch!
In the market there is an app called "PrintShare" Its a paid app and works for me. I'm able to print doc, pic, emails, etc. I do however, have my printer plugged into my router, but I am not sure if this is needed. So check it out.
Hope this helps.
"PrintBot" can be an good option, I have used it. Using this app, you can print any kind of documents(image, pdf, text, docs etc.) from your mobile through wifi.
HP makes a laser printer with wifi. You still need an app, but the printer doesn't have to physically use the router.
HP also had older printers with IR. We used to print from Palm PDAs.
