Print from phone not formatting correctly
CharlesLewis
When I print a document from my phone, sometimes it does not format correctly. If I print the document from my computer, it is one page formatted the way that it should be. When I print from my phone even if I have set it on print view, it may be two pages. I suspect I have a setting that needs to be changed, but I have no idea what it is.
I'm hoping someone can help.
HP laser jet using Printer Share
what's the model number?
you will need HP Print Service Plugin which has the drivers needed to print on an android device:
https://play.google.com/store/apps/details?id=com.hp.android.printservice
here read this:
https://www.hp.com/us-en/shop/tech-takes/how-to-print-from-google-android-phone
it is better if you deal specifically with HP rather than deal with a 3rd party app to print from a HP printer.
if you have a HP smart printer than you can use HP Smart:
https://www.hpsmart.com/us/en
here read this:
I have HP Smart installed, but often that's not listed in the share menu.
What are you trying to print from your phone? I rarely have any trouble printing from my z fold 3. What file format are they?
