Help Print options
bxtzd3
Looking for a printing option for the tab. I need it for work. Hp printers on the wifi network. Tried printshare but i want it intergrated like moto print. Thanks in advanced.
I just installed print by Euro smart. it set up very easy and eureka great with my HP photo smart printer. Was $5.
thats what I use now, cloud print. I am trying out the free version with ads but so far so good. As an added benefit I can now also print from my Droid Bionic too. I think the full on version without ads is 2.99 or so. I think I'll buy it.
I had to download Google Chrome (on the PC) and enable Google Cloud Print.
It works!
I bought printshare. When i go to print it takes me to a window that has print on the bottom but reopen the page i am on and i have to redo whatever i did. If itt was a form i would have to fill it out again. I use moto print on my phone. Wish it worked here. Good app
Ok. Outy of the 2 i downloaded hp app and printshare they both stink. I cant print files from the web on either. I downloaded it to pdf and still cant. What the hell am i doing wrong.
I tried that as well. But when i try it pops up the window and says no doc or unsupported. I dont get it. Motoprint is flawless.
cloud print rocks....just installed on my Galaxy Tab & Razr today. Thanks for all the tips and recommendations. These Forums are defintely a good resource
Ya i would love to cloud print. Just dont have a pc at work able to connect. Firewalls and stuff. They may get ipads so then they would have to go to the cloud
so i got the cloud set up at work, ssshhhh, dont tell them. Now i can print a test page. But nothing from the web or xl files. I would love to say its me but i tried several different thing. Saved it to a file or the other ways it says. Im at a loss.
I can't help you, but I think it would help others help you if you told us what app you're trying to use. Is it the Cloud Print I mentioned, or something else?
Did you read the instructions? It's kind of funny but you click on "share" from within an app, then you share your document with cloud print. Different apps do things differently so it's not all the same, not very intuitive. Sometimes you have to send it, not share it, without even opening it. Kind of klunky but once you figure it out it works.
well i did the share what happens is i go to share and no matter what way i chose, pdf or direct web page or download it sends it but dont print. The direct only show 3 dots on the screen no page. I dont get why motoprint works wifi so flawlessly and samsung cant get it. I love this tablet just want to print from it.
Are you guys opening the program first?
Heres what I see. While looking at this page I pressed the menu button at the bottom, then share. To print this page I would press cloud print.
Haha well it seems there just might be an argument for that screen cap button that everyone complains about. It is in the way but its pretty handy too.
well my menu is on the top, but same thing. I woulld post a screen cap but i honestly dont know how. It asked for a url and my pic is on the tab.
But when i hit share then cloud it askes what format. Pdf normal pdf newspaper direct print or download and print. None of them work. The direct print opens cloud printer and shows 3 dots. Nothing else. The pdf's fail. And download and print fails as well. I did print a xls sheet. Of course all 47 pages printed due to not being able to highlight and print, thats another story.
Im thinking 3.2 may be the issue. I am at a loss.
Photobucket.
But something's different.
When I press cloud print it asks me if I want to print the web page or just text.
Maybe you should look at the pc end, make sure chrome is running, in the background, and your printer and eveything is ok.
I wish I could be of more help. I've had my tab since Christmas.
Photobucket.
I get that option. Then once i pass that is when the other options pop up. Are you on 3.2?
Yes.
I tried it. I saw the three dots. I chose direct print.
Hit the down arrow in the lower left corner of the screen to get rid of the keyboard then you can see the buttons at the bottom. Hit print. Then print again. I swear you have to press about 5 or 6 buttons to print a page. Its not easy thats for sure.
I'm starting to go through windows withdrawals. Haha
Haha my bad.I finally went and looked at what I was printing.
At first I thought the printer was spitting out blank pages.
Looking closer, guess what it was printing. 3 dots. Haha I typed something in front of the dots and it printed out.
I ended up on the last option, download then print. Make sure you choose the right printer and setup.
I fell for that one already. This is really way harder than it needs to be.
