print to canon printer
  • Start date Start date
A
Android Question
Guest
How do i print from my tablet to my canon wireless printer
Hi Guest, If you have the Samsung tablet then I believe you can only use a Samsung printer. I tried to set mine up through the Wi-Fi through my belkin router but it could not connect. I suggest you do a Google for setting up a small home network and see if you can get any more info from that. Sorry not much help.
May I suggest if you are going to use this forum a lot, it would be helpful to other members to see what gear you have so if possible can you fill in your profile.
