Printer question
iDapzZ
If I by a all in one printer I think that's what they are it says print copy scan on the description.
Can I reside a image to print with one of these and my nexus 5i want to use it for stencils to practice tracing
Hey iD... not that up on printers but I think you will find an all in one is addressable in a number of ways. WIFI support, it will usually have an email address. You can email print jobs directly to the printer. You can use the a cloud to spool printing to your printer as well. I don't know just what manner you will find the easiest. Perhaps some of your fellow N5 owners will have some input. Good luck.
Hopefully mainly I just want a printer I can use with my n5 or smartphone in general and be able to resize the image so I can learn to trace at different sizes
