jacobbrandon19
Member
I am on the stock PRL 61007. Could anyone tell me if there would be any benefit to changing it? If there is a possibility of it helping could anyone link me to a thread for dummies about changing prl?
there is one on page 2,3,4. i don't mess with them others do, mine seems ok some will say it helps and others keep searching so might not really help.I am on the stock PRL 61007. Could anyone tell me if there would be any benefit to changing it? If there is a possibility of it helping could anyone link me to a thread for dummies about changing prl?
I have seen improvement in 3g speed and signal by switching my prl. Look through the all things root section. There are quite a few threads on the subject.
what is the latest prl you used
i'm still on the 61007,that came with phone. and have had no problems with mine except for a short time when they were working on towers i guess. only have some bad areas here and there but evryone does even all carriers, just some dead zones i guess.I was using 12121 but decided to give the Boost stock prl a try again for the hell of it since they've done some work on the tower in my area. When I first got the phone it was running 61007. I updated the prl not to long ago and Boost has changed the prl to 61008. That is what I'm running ATM and it's doing well.![]()
im on 12123 and its running great. Good service and good speeds. Im not going to change it . Dont fix whats not broken. Or i might update it to something newer if available
