Yeah I still have 2.1 so I guess I'll have to root my phone. Thanks for the help.
Ok so I rooted my phone, but I don't have this Froyo thing. What is that?
You will need Android 2.2, don't know if the Ally has that yet. This will make your default location the SD card so everything from that point on will get installed there.
To clarify for other new users, this is not correct.
Installation to SD card needs to be allowed by the app developer. I believe the option to install to SD card by default also depends on the app.
You should not assume all apps will install on the SD card. They won't.
I guess I misunderstood this part of your post. It looks like you are saying that Android 2.2 makes the default location the SD card (without any hacks needed).
Thanks for providing the link.
Unless they're looking for a scapegoat for a warranty/insurance claim.Verizon or any other carrier doesn't care. It make no difference from their point of view.
