Problem accessing notifications
Says I have 1 notification, but when I click the link it goes to my user CP, the notifications don't come up as they used to and I can't see my likes etc. Refreshing the page doesn't help.
That's just it, I don't get the drop-down any more. It just takes me straight to my control panel. If I hover over the notification link with my cursor I can see the CP URL- http://androidforums.com/usercp.php
Mine does that on a mouse-over on the word Notifications as well, but I still get the drop down.
No link on hover and drop-down working on the little triangle to the right of the Notifications.
Hmmmmm....
Please try clearing your cache and report back?
If that doesn't work - please let know which browser and OS you're using, thanks!
Ok so this is still happening, it took a while for me to report back because I didn't get any notifications. I have one waiting right now, there is no drop-down available and the triangle to click on is not there. Clicking on the notifications link takes me right to my control panel. I did clear my cache and it made no difference. Browser is Firefox 21, OS is Win7 64-bit.
You should be able to just click the number there
Weird. :(
Ok - maybe try various settings under Content, advanced Javascript. Also under the Advanced tab on mine, I'm using hardware acceleration.
I'm also up-to-date on Adobe Flash although - pretty darned sure that's just Javascript up there, not anything to do with Flash.
But I'm just tossing that out there because in my experience, you just never know about side-effects with configuration differences. And I know that sounds lame but there it is. :o
Weird. :(
I was able to reproduce the problem by disabling Javascript altogether (Firefox 22, Arch Linux)
So, make sure Javascript is enabled and you should be good to go! :)
Reproduced on Chrome 30 on the same OS
