Help Problem after ringing engaged number
peter7769
Hi all
I noticed a problem last night, my phone is set to turn off the screen when I make a call, so I unlocked my phone rang a number and it was engaged, after a few seconds the phone then returned to the lock screen, instead of staying unlocked, I tested it again with the same results, so I changed the setting to keep the screen switched on when I made a call, this time after the engaged tone finished it stayed unlocked! Set it back to normal and back to the lock screen it went, has anyone else had this problem or can someone check it for me :confused:
Pete
Sent from my Galaxy Note 2 using Tapatalk 2
My S3 did that too. If I moved it away from my ear quick enough and the proximity sensor reacted and lit the display again, it would prevent it from locking again though.
Auto redial would be good! What I did most of the time was just hold it in my hand and ring then press redial when it said busy. Saved it from locking and the quickest way to try the number again :-)
Good idea, will try it next time ;)
Do not have my Note yet {Verizon you are killing me!} but sounds like security is set to lock the device immediately... So when the screen dims, it locks. Can you check that in settings?
Hi again
My note2 has auto-redial option in phone>call settings>additional settings
Roger
In my "additional settings" there is no auto redial. Maybe it's somewhere else. Will have to dig around more.
No its not set to lock immediately, its set to lock after 5 minutes of no use.
Hi
Contents of my "additions settings"
Its a carrier unlocked phone bought in France.
Roger
Thats very strange, mine is carrier unlocked in the UK and here is my settings...
