Help problem connecting D2 to computer
RonArm
Trying to get pictures from my D2 phone to my XP computer.
When I connect the USB cable the computer goes into continous reboots.
Try a different USB port. For example, if you are using one on the front, try the one on the back.
Try a different cable. If you don't have one and you are willing to spend a few bucks, go to monoprice.com and order one. It will be cheap.
If possible, try it on someone else's computer and see if you have the same issues.
