Help problem connecting galaxy nexus to IPAD through blue tooth
Hi megamen,
Did the pairing process ask you for pins on both devices? That happens to me when paring two phones... I'd assume the process was relatively standard...
I'm going to move this to a forum for the nexus, I'm sure they'll be able to help you out.
9to5
Hello and welcome to these forums. I'm not ipad wise but I'll take a stab at an answer to your problem. I'm guessing both devices want to be the host BT device.
I know your Galaxy wants to be the host and will search for a pairing device or guest.
I assume the ipad is the same. Both devices will pair with a guest device such as a BT keyboard, headsets, etc. They will not pair to each other. I might well be wrong and I do have an area where there are those that are more versed in your situation to help you. Here is a link to that area:
Android Lounge - Android Forums
I tried connecting to an iPad and never had any luck. If I remember correctly, I think they both saw each other but nothing I tried was successful in getting them to talk.
