surgerush
I have the I537 unlocked and I'm using it on T-mobile.
It's being very sporadic, it only wants to work when it wants to. Like right now, I'm getting 4G LTE, but a few minutes ago it wouldn't even connect. I was out earlier, and the entire time I had no data connecting whatsoever, and when I can get data, it seems to only want to connect to edge.
I just upgraded from the S2, it was the T-mobile version and I never had any trouble getting a good 4G signal or any data problems around where I live whatsoever. When I looked at the specs, it looked like they had the same radio bands plus, so I figured I should be getting the same results as with my last phone.
I've set the Network Operator to manual and set it to T-Mobile, I've checked the APN and it looks to be what it's supposed to according to others (on the epc.tmobile.com . Mobile Data is definitely ticked. I can still make calls and text, just won't connect to data.
Any help would be greatly appreciated.
