Problem Dialing Extensions
steelersmb
There is a major dialing issue when you have contacts with an extension number as a x with the extension. It appends the extension number when dialing and causes a bad number. Is there a fix for this? I sync with work contacts and this is not good.
Sent from my PC36100 using Tapatalk
If anyone is interested, aTakephone just came out with an update to handle dialing extensions. It will insert a hard or soft pause automatically. Has some other new features as well.
