I am trying to learn building apps for the android.
I have a few TextViews etc and a small view in the top left corner into which I can draw shapes. I have placed the buttons, view etc on main screen using xml (DroidDraw). All these show and work fine. I used the following to display them:
public void onCreate(Bundle icicle) {
super.onCreate(icicle);
setContentView(R.layout.main);
Is it possible to draw directly into this xml view? I have managed to change its background colour but cannot draw into it.
Since I couldn't draw inside the xml view I tried using the extend View approach.
E.g.
public class DrawView extends View {
private Paint paint;
public DrawView(Context context) {
super(context);
paint = new Paint();
I can activate this by using:
newgame.setOnClickListener(new View.OnClickListener() {
public void onClick(View v) {
CreateView();
setContentView(gV);
public void CreateView()
gV = new DrawView(this);
This creates a new view which fills the screen and paints correctly etc, but it hides all the buttons of main screen.
I don't mind which method I get to work but I need either:
1. how do I draw inside a view built inside main.xml;
or
2.how do I display a View created class DrawClass inside the main screen without covering any controls in the main.xml. i.e is there an alternative to setContentView(gV); which will insert a view into one section of screen?
E.g.
super(context);
CreateView();
setContentView(gV);
or
