I have not come across this result in any of the forums I have read
when I used the adb push try3 /data/local
what is returned is
585 KB/s (0 bytes in 74512.0000 sec)
something to that affect...i am assuming its a time out, but I really don't know what would be going on
to gain root if you are in 1.6 just use this http://androidforums.com/behold-2-all-things-root/128131-get-root-based-new-1-6-finally.html or if in 1.5 then use this http://androidforums.com/behold-2-a...n-images-available-latest-t-mobile-stock.html to go to 1.6 and flash the rooted kernel.
if you are using bh_man's roms then it already has root access.
no I have not rooted my phone yet...That is what I am trying to do...I still of the stock of Behold 2 on it
Firmware version: 1.5
Baseband: T939UVJA3
Kernel Version: 2.6.27
ok...the link to ODINs files is no longer there...so do you flash the rom before you root the behold 2?
