Apps Problem in List View
ky0ko
Hi guys,
I always encounter this problem but dont know what cause it.
06-05 15:14:33.369: E/Suysing Error(277): Binary XML file line #1: Error inflating class com.suysing.hsfa.views.CustomerListItem
Here are my codes.
XML Layout
Code:
<com.suysing.hsfa.views.CustomerListItem
    android:id="@+id/CustomerListItem"
    android:layout_height="fill_parent"
    android:layout_width="fill_parent"
    xmlns:android="http://schemas.android.com/apk/res/android">
        <CheckBox
            android:id="@+id/customer_tag"
            android:layout_width="wrap_content"
            android:layout_height="wrap_content"
            android:gravity="left"
            android:focusable="false"/>
        <CheckBox
            android:id="@+id/customer_status"
        <TextView
            android:id="@+id/customer_id"
            android:layout_weight="0.4"
            android:textColor="@color/white"
			android:width="0dp" />
        <TextView
            android:id="@+id/store_name"
            android:layout_weight=".6"
</com.suysing.hsfa.views.CustomerListItem>
Views
Code:
package com.suysing.hsfa.views;
import com.suysing.hsfa.R;
import com.suysing.hsfa.domain.CustomerRegistration;
import android.content.Context;
import android.widget.CheckBox;
import android.widget.LinearLayout;
import android.widget.TextView;
public class CustomerListItem extends LinearLayout{
	private CustomerRegistration customer;
	private CheckBox trans_Tag;
	private CheckBox trans_Sent;
	private TextView trans_CustomerID;
	private TextView trans_StoreName;
	public CustomerListItem(Context context) {
		super(context);
	public void setCustomer(CustomerRegistration customer) {
		this.customer = customer;
		trans_Tag.setChecked(customer.getTag());
		trans_Sent.setChecked(customer.getSent());
		trans_CustomerID.setText(customer.getCustomerId());
		trans_StoreName.setText(customer.getCustomerName());
	protected void onFinishInflate() {
		super.onFinishInflate();
		trans_Tag = (CheckBox)findViewById(R.id.transaction_tag);
		trans_Sent = (CheckBox)findViewById(R.id.transaction_status);
		trans_CustomerID =(TextView)findViewById(R.id.customer_id);
		trans_StoreName=(TextView)findViewById(R.id.store_name);
	public CustomerRegistration getCustomer() {
		return customer;
Adapter
Code:
package com.suysing.hsfa.adapter;
import java.util.ArrayList;
import com.suysing.hsfa.views.CustomerListItem;
import android.util.Log;
import android.view.View;
import android.view.ViewGroup;
import android.widget.BaseAdapter;
public class CustomerListAdapter extends BaseAdapter {
	private ArrayList<CustomerRegistration> customer;
	private Context context;
	public CustomerListAdapter(ArrayList<CustomerRegistration> customer, Context context) {
		super();
		this.context = context;
	public int getCount() {
		return customer.size();
	public CustomerRegistration getItem(int position) {
		return  (null == customer)? null : customer.get(position);
	public long getItemId(int position) {
		return position;
	public View getView(int position, View convertView, ViewGroup parent) {
		CustomerListItem cli = null;
		try {
			if (null==convertView){
				cli = (CustomerListItem)View.inflate(context, R.layout.transaction_customer, null);
			}else{
				cli = (CustomerListItem)convertView;
			cli.setCustomer(customer.get(position));
		} catch (Exception e) {
			Log.e("Suysing Error", e.getMessage());
		return cli;
	public void forceReload() {
		notifyDataSetChanged();
