Root problem in samsung i 5700 spica
kapoo
if can any one help please do, I connected the phone and download the OPS file and PDA file by Odin then message<1> appeared to me and I plugged the phone then I found screen on my phone showed multi options and pressed the first option reboot now by mistake. my phone now dead ,then I tried to connect it by Odin again and I started download and nothing happened to the phone(the status bar of download in the phone and in the Odin)the left corner in Odin which display "4com" not moved I left it 4 hours and nothing changed.... please HELP :( . And when I tried to press volume down +answer call+ switch off and I choice apply any zip from SD I found this : E:cant format system:
E: failure at line 2:
Format system: installation aborted
What can I do now ?
