Help Problem in screen.please inter my thread
Wise11
Hi
When I keep my mobile away from my hand.the screen turns on then turns off by itself why?
I did not touch screen
Please elaborate.
Is the screen off, then if you move your hand over the screen it turns on for a second, then turns off?
What device do you have? Perhaps there is a display setting that senses movement?
ok, and forgive me if I'm not exactly following what is going on....
What are you actually doing when the screen turns on then off?
You state you " keep my mobile away from my hand" ...what do you mean? --- the screen was originally off when you move your hand away, then the screen turns on briefly, then turns back off?
You state you " keep my mobile away from my hand" ...what do you mean? --- the screen was originally off when you move your hand away, then the screen turns on briefly, then turns back off?[/QUOTE]
Yes exactly
Hmm, not sure but is there a setting called, "smart stay" that is enabled?
I'm a little rusty on the Samsung side of things but that setting comes to mind.
When you're on a call, the proximity sensor will turn the screen off when you hold the phone up to your ear, then turn it on again when you move it away. When you're not on a call it shouldn't do anything unless it's being used by an app or setting.
The S5 has a built-in app called "Air Wake-Up" which lets you use your hand over the proximity sensor to turn the screen on instead of pressing the power or home buttons. I'm not sure if the S4 has this as well, but if it does you'll find in under Settings/Accessibility/Dexterity and Interaction. If it's there and turned on, turn it off.
I checked all settings.just when I Leave my mobile screen light on then turns off repeatadilly .I Do not know why?
Well, if you have checked all your settings, and everything looks good, my guess would be to either boot into safe mode to see if the problem persists or factory reset it.
If it still happens in safe mode, then save what you need to save and factory reset it.
Your proximity sensor may be acting up or on the fritz.
