Help Problem Installing apps
I just bought my transformer today so im still new to the tablet scene. I just recently took it out of the box and went through setting it up but for some reason when trying to install apps nothing goes through.
Under my apps in the market place it says apps not installed and shows the apps i am trying to install. I click install all it goes through the process, but then they show up again under apps not installed. Is there something im not seeing?
Happens sometimes. Not sure why but just go through settings, manage apps and force stop the market app. Then restart the market. Should be fixed
After forceclosing the marketplace and putting all of the apps back in the installation que, the same problem persists. Does anyone know a solution to this problem? It seems like a pretty huge problem to not be able to install any applications........
If it helps find the problem, it also persists with trying to update programs alllready installed. Google Maps is also stuck in the update que and will continue to be there even after i click update.
