problem joining contacts in Ray
i tried joining two contacts in the Ray. i did the whole procedure and in the end it said contacts joined. however actually they were not joined....
then i did the same through my pc and this time they joined...
is this another 'bug' ? how to join contacts in the Ray?
please advise!
That is odd and I can honestly say I have not come across this problem before. You may want to back up the contacts and then clear the data from the contacts application:
Main Menu > Settings > Applications > Manage Applications > All > Contacts > Clear data. (Just make sure you have a copy of them on your SIM or memory card before doing so.)
