Problem logging into gmail using my android phone
  • Start date Start date
A
Android Question
Guest
Each time I try to log in, I get error 503 80315: The username and password entered is incorrect. However, when logging in via computer, I can access my gmail.
It's got to be something to do with the account Incoming Setting in email.
Most likely it's the password, of course though it may be the username (I just noticed my hotmail one has a backslash ("\") in front of it but my gmail doesn't :confused:) - or the IMAP server (imap.gmail.com), port number (993) or security setting (SSL/TLS).
Check each of these carefully. If you have a complex password (as you should), then it may help to type the password into a note (or something) then cut & paste it into the settings.
