Root Problem on CM7 with auto brightness
steslatt
Android Expert
I'm running the Cyanogenmod CM7 and when I use the auto brightness function it doesnt work propery. It is either very dim of very bright and it switches between the 2 when I lock and unlock the screen. Is anyone else having the same problem or know why it is doing this?
I am having same issue. Display taking too much battery life. There is setting for auto brightness manual level but I still have to check that out in mean while I am changing brightness from power bar shortcut as needed and saving battery life
