Grimbarian
I am trying to print from a Samsung Tab S 10.5 to a Samsung Xpress M2022W laser printer.
Samsung Print Service Plugin installed. Tablet shows (WiFi) Direct-sFM2020 series Saved and Secured so WiFi signal from printer is received and displayed. When I try and connect or to add a printer a Box appears asking for a Password. I havent been asked for a password and every password I have previously used has been tried. I have also tried with all the passwords etc that are used to set my WiFi router but always get "Incorrect Password" message. The Tablet works fine on the Internet so that part of it is working O.K.
Can anybody tell me how I find out what the correct password should be or how I can change the password to enable the printer connection.
Many thanks .................Grimbarian
