Root Problem restoring with Titanium on Bionx ROM
rdefino
I loaded the latest release of Bionx 2.0.4 with the patch.
When I do a restore with Titanium pro, the restore hangs on doing the restore. It just sits there and doesn't continue. It will restore a good amount of them, but eventually hangs.
Anyone else seeing this?
You're not trying to restore system app settings are you? You should NEVER do that from one ROM to another, including stock. ONLY restore user apps and settings.
You can filter the system apps that are backed up in TiBU so you only see the user apps. That way, when you go to restore, you only restore the user apps and settings.
