Help Problem Root and F. Reset?
  • Thread starter Thread starter Problem Factory reset
  • Start date Start date
P
Guest
Hi everybody, I'm new in this community and I wanna solve this question than I can't find anywhere:
Is there any problem if a do a Factory Reset (from the recovery) to a rooted device? Will my phone work without problem? And if there isn´t any problem, do I lose the root access?
Thank you very much to everyone!!!!
P.S: My phone is a Samsung Galaxy Core 2 SM-G335M
Rooting modifies the ROM. All a factory reset does is delete user-installed data, apps and settings. So no, a factory reset won't affect root.
For the same reason it also will not fix any problems with the rom due to errors in rooting or removing apps that should not have been removed. Just mentioning this to be clear, since people often assume that "factory reset" will restore the original rom, whereas in reality it won't undo any modifications to the system software at all.
