Root Problem root by Super one click
askksa
By Super one show Click the following problem
Starting ADB Server…
* daemon not running. starting it now on port 5037 * OK
Waiting for device…
OK
Pushing psneuter…
OK
chmod psneuter…
OK
Running psneuter…
FAILED
Please help
I got the same error - the root failed.
What can I do In order to be able to root my Samsung ace?
Thank you!
Been trying to root LG PHOENIX android 2.3.6 with SuperOneClick with no luck. Here is what happens.
Killing ADB Server...............Kill Server
Starting ADB Server............Start Server..........4.41s..........*daeman not running. starting it now on port 5
Waiting for device................WaitForDevice.....0.05s
Getting Manufacturer...........Getproperty..........0.14s.........LGE
Getting model.....................Getproperty..........0.14s.........LG-P505CH
Getting version....................Getproperty...........0.14s.........eng.samson.yeo 20110418.170902
Checking if rooted................Checkifrooted........031s.........False
Installing BusyBox(temporary)....PushFile.....0.66s.........1822KB/s (1075144bytes in 0.576s)
Installing BusyBov(temp) Step.....ChangeMode....0.14s
Rooting device,,,Step #1........PushFile.........1634KB/s (585781 bytes in 0.350s)
Rooting device,,,Step #2........ShellCommand......0.15s
Rooting device,,,Step #3........ShellCommand......0.15s
Rooting device,,,Step #4........ShellCommand......0.14s......export PSI=""property service neutered killing
Rooting device,,,Step #5........WaitForDevice......9.06s
ROOT
* daemon started successfully *
$ export PS1="" getprop ro.build.version.release > /data/local/tmp/output 2>&1 export TEMPRANDOM=84332 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output 2.2.2 END:84332export PS1="" getprop ro.product.manufacturer > /data/local/tmp/output 2>&1 export TEMPRANDOM=94500 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output LGE END:94500export PS1="" getprop ro.product.model > /data/local/tmp/output 2>&1 export TEMPRANDOM=37242 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output LG-P505CH END:37242export PS1="" getprop ro.build.version.incremental > /data/local/tmp/output 2>&1 export TEMPRANDOM=78056 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output eng.samson.yeo.20110418.170902 END:78056export PS1="" ls -l /system/xbin/su > /data/local/tmp/output 2>&1 export TEMPRANDOM=75890 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output /system/xbin/su: No such file or directory END:75890export PS1="" ls -l /system/bin/su > /data/local/tmp/output 2>&1 export TEMPRANDOM=62280 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output /system/bin/su: No such file or directory END:62280export PS1="" chmod 755 /data/local/tmp/busybox > /data/local/tmp/output 2>&1 export TEMPRANDOM=34329 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:34329export PS1="" chmod 700 /data/local/tmp/psneuter > /data/local/tmp/output 2>&1 export TEMPRANDOM=73346 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:73346export PS1="" cd /data/local/tmp/ > /data/local/tmp/output 2>&1 export TEMPRANDOM=80672 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:80672export PS1="" export TEMPRANDOM=92036;export PS1=END:$TEMPRANDOM;./psneuter export PS1="" property service neutered. killing adbd. (should restart in a second or two) $ export PS1="" /data/local/tmp/busybox mount -o rw,remount /system > /data/local/tmp/output 2>&1 export TEMPRANDOM=19748 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output mount: permission denied (are you root?) END:19748export PS1="" /data/local/tmp/busybox mount > /data/local/tmp/output 2>&1 export TEMPRANDOM=47931 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output rootfs on / type rootfs (ro,relatime) tmpfs on /dev type tmpfs (rw,relatime,mode=755) devpts on /dev/pts type devpts (rw,relatime,mode=600) proc on /proc type proc (rw,relatime) sysfs on /sys type sysfs (rw,relatime) /dev/block/mtdblock1 on /system type yaffs2 (ro,relatime) /dev/block/mtdblock9 on /data type yaffs2 (rw,nosuid,nodev,relatime) /dev/block/mtdblock3 on /lgdrm type yaffs2 (rw,nosuid,nodev,relatime) tmpfs on /mnt/asec type tmpfs (rw,relatime,mode=755,gid=1000) /dev/block/mtdblock8 on /cache type yaffs2 (rw,nosuid,nodev,relatime) /dev/block/vold/179:1 on /mnt/sdcard type vfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) /dev/block/vold/179:1 on /mnt/secure/asec type vfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) tmpfs on /mnt/sdcard/.android_secure type tmpfs (ro,relatime,size=0k,mode=000) END:47931export PS1="" /data/local/tmp/busybox mount -o rw,remount /dev/block/mtdblock1 /system > /data/local/tmp/output 2>&1 export TEMPRANDOM=24386 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output mount: permission denied (are you root?) END:24386export PS1="" /data/local/tmp/busybox mount > /data/local/tmp/output 2>&1 export TEMPRANDOM=93456 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output rootfs on / type rootfs (ro,relatime) tmpfs on /dev type tmpfs (rw,relatime,mode=755) devpts on /dev/pts type devpts (rw,relatime,mode=600) proc on /proc type proc (rw,relatime) sysfs on /sys type sysfs (rw,relatime) /dev/block/mtdblock1 on /system type yaffs2 (ro,relatime) /dev/block/mtdblock9 on /data type yaffs2 (rw,nosuid,nodev,relatime) /dev/block/mtdblock3 on /lgdrm type yaffs2 (rw,nosuid,nodev,relatime) tmpfs on /mnt/asec type tmpfs (rw,relatime,mode=755,gid=1000) /dev/block/mtdblock8 on /cache type yaffs2 (rw,nosuid,nodev,relatime) /dev/block/vold/179:1 on /mnt/sdcard type vfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) /dev/block/vold/179:1 on /mnt/secure/asec type vfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) tmpfs on /mnt/sdcard/.android_secure type tmpfs (ro,relatime,size=0k,mode=000) END:93456export PS1="" mount -o rw,remount /dev/block/mtdblock1 /system > /data/local/tmp/output 2>&1 export TEMPRANDOM=12871 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output mount: Operation not permitted END:12871
SHELL ROOT
$ export PS1="" getprop ro.build.version.release > /data/local/tmp/output 2>&1 export TEMPRANDOM=84332 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output 2.2.2 END:84332export PS1="" getprop ro.product.manufacturer > /data/local/tmp/output 2>&1 export TEMPRANDOM=94500 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output LGE END:94500export PS1="" getprop ro.product.model > /data/local/tmp/output 2>&1 export TEMPRANDOM=37242 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output LG-P505CH END:37242export PS1="" getprop ro.build.version.incremental > /data/local/tmp/output 2>&1 export TEMPRANDOM=78056 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output eng.samson.yeo.20110418.170902 END:78056export PS1="" ls -l /system/xbin/su > /data/local/tmp/output 2>&1 export TEMPRANDOM=75890 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output /system/xbin/su: No such file or directory END:75890export PS1="" ls -l /system/bin/su > /data/local/tmp/output 2>&1 export TEMPRANDOM=62280 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output /system/bin/su: No such file or directory END:62280export PS1="" chmod 755 /data/local/tmp/busybox > /data/local/tmp/output 2>&1 export TEMPRANDOM=34329 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:34329export PS1="" chmod 700 /data/local/tmp/psneuter > /data/local/tmp/output 2>&1 export TEMPRANDOM=73346 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:73346export PS1="" cd /data/local/tmp/ > /data/local/tmp/output 2>&1 export TEMPRANDOM=80672 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:80672export PS1="" export TEMPRANDOM=92036;export PS1=END:$TEMPRANDOM;./psneuter export PS1="" property service neutered. killing adbd. (should restart in a second or two) $ export PS1="" /data/local/tmp/busybox mount -o rw,remount /system > /data/local/tmp/output 2>&1 export TEMPRANDOM=19748 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output mount: permission denied (are you root?) END:19748export PS1="" /data/local/tmp/busybox mount > /data/local/tmp/output 2>&1 export TEMPRANDOM=47931 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output rootfs on / type rootfs (ro,relatime) tmpfs on /dev type tmpfs (rw,relatime,mode=755) devpts on /dev/pts type devpts (rw,relatime,mode=600) proc on /proc type proc (rw,relatime) sysfs on /sys type sysfs (rw,relatime) /dev/block/mtdblock1 on /system type yaffs2 (ro,relatime) /dev/block/mtdblock9 on /data type yaffs2 (rw,nosuid,nodev,relatime) /dev/block/mtdblock3 on /lgdrm type yaffs2 (rw,nosuid,nodev,relatime) tmpfs on /mnt/asec type tmpfs (rw,relatime,mode=755,gid=1000) /dev/block/mtdblock8 on /cache type yaffs2 (rw,nosuid,nodev,relatime) /dev/block/vold/179:1 on /mnt/sdcard type vfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) /dev/block/vold/179:1 on /mnt/secure/asec type vfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) tmpfs on /mnt/sdcard/.android_secure type tmpfs (ro,relatime,size=0k,mode=000) END:47931export PS1="" /data/local/tmp/busybox mount -o rw,remount /dev/block/mtdblock1 /system > /data/local/tmp/output 2>&1 export TEMPRANDOM=24386 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output mount: permission denied (are you root?) END:24386export PS1="" /data/local/tmp/busybox mount > /data/local/tmp/output 2>&1 export TEMPRANDOM=93456 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output rootfs on / type rootfs (ro,relatime) tmpfs on /dev type tmpfs (rw,relatime,mode=755) devpts on /dev/pts type devpts (rw,relatime,mode=600) proc on /proc type proc (rw,relatime) sysfs on /sys type sysfs (rw,relatime) /dev/block/mtdblock1 on /system type yaffs2 (ro,relatime) /dev/block/mtdblock9 on /data type yaffs2 (rw,nosuid,nodev,relatime) /dev/block/mtdblock3 on /lgdrm type yaffs2 (rw,nosuid,nodev,relatime) tmpfs on /mnt/asec type tmpfs (rw,relatime,mode=755,gid=1000) /dev/block/mtdblock8 on /cache type yaffs2 (rw,nosuid,nodev,relatime) /dev/block/vold/179:1 on /mnt/sdcard type vfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) /dev/block/vold/179:1 on /mnt/secure/asec type vfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) tmpfs on /mnt/sdcard/.android_secure type tmpfs (ro,relatime,size=0k,mode=000) END:93456export PS1="" mount -o rw,remount /dev/block/mtdblock1 /system > /data/local/tmp/output 2>&1 export TEMPRANDOM=12871 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output mount: Operation not permitted END:12871* daemon not running. starting it now on port 5037 *
export PS1="" $ whoami > /data/local/tmp/output 2>&1 export TEMPRANDOM=10479 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output whoami: permission denied mount: Operation not permitted END:10479export PS1="" busybox whoami > /data/local/tmp/output 2>&1 export TEMPRANDOM=55033 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output busybox: permission denied mount: Operation not permitted END:55033export PS1="" /data/local/tmp/busybox whoami > /data/local/tmp/output 2>&1 export TEMPRANDOM=12501 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output whoami: unknown uid 2000 END:12501export PS1="" getprop ro.product.manufacturer > /data/local/tmp/output 2>&1 export TEMPRANDOM=74165 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:74165export PS1="" getprop ro.product.model > /data/local/tmp/output 2>&1 export TEMPRANDOM=45163 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:45163export PS1="" getprop ro.build.version.incremental > /data/local/tmp/output 2>&1 export TEMPRANDOM=56526 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:56526export PS1="" getprop ro.build.version.release > /data/local/tmp/output 2>&1 export TEMPRANDOM=60787 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:60787export PS1="" chmod 700 /data/local/tmp/psneuter > /data/local/tmp/output 2>&1 export TEMPRANDOM=52417 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:52417export PS1="" cd /data/local/tmp/ > /data/local/tmp/output 2>&1 export TEMPRANDOM=70433 export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output END:70433export PS1="" export TEMPRANDOM=11226;export PS1=END:$TEMPRANDOM;./psneuter export PS1="" mmap() failed. Operation not permitted END:11226
AFTER THIS ID DOES NOTHING
