Apps problem running hello world app!
AdilES
Hey... i'm a beginner in android development. I started with hello world app, but i get the following error-
[2011-08-08 07:56:36 - bucky] ------------------------------
[2011-08-08 07:56:36 - bucky] Android Launch!
[2011-08-08 07:56:36 - bucky] adb is running normally.
[2011-08-08 07:56:36 - bucky] Performing com.infinity.android.adil.BuckyActivity activity launch
[2011-08-08 07:56:36 - bucky] Automatic Target Mode: Preferred AVD 'Adils_AVD' is not available. Launching new emulator.
[2011-08-08 07:56:36 - bucky] Launching a new emulator with Virtual Device 'Adils_AVD'
[2011-08-08 07:56:39 - Emulator] invalid command-line parameter: Files.
[2011-08-08 07:56:39 - Emulator] Hint: use '@foo' to launch a virtual device named 'foo'.
[2011-08-08 07:56:39 - Emulator] please use -help for more information
I'm using eclipse IDE in Windows. Please Help.
While I don't know how to fix the other stuff, to fix the problem I quoted, you need to have no spaces in the directory for your Android SDK folder. For instance if its in C:\Documents and Settings\whatever\android-sdk, then it won't work because of the spaces in Documents and Settings. Therefore, a simple fix is to put it in C:\. Then make sure in Eclipse you go to Window > Preferences > Android and point to where the SDK is.
I hope this helps, I had the same problem earlier today. :)
I had this problem too, and am using Win7. If you installed the SDK to your "ProgramsFiles(x86)" folder, then change the quoted section to Progra~2. It is a Win7 thing with SDK.
