problem switching to 3G in Samsung Galaxy S Duos
milindg1
Hi,
I'm facing problem with my Samsung Galaxy S Duos. I can't seem to keep it in 3G mode. It displayed 'H' just once and then it has reverted back to 'E' (Edge). I've tried restart many times.
It has Andriod 4.0.4 preloaded. I've not rooted it or anything especially as i dont know what it is or how to do that.
Any help will be appreciated.
Actually H & E depends up on data it receives, for only 3g apply only WCDMA in network mode. if u r are using in s2, change another sim to gsm then the sim u want to use automatically turns to h. if u only use single sim try network mode technique
If you are using both 3G sim cards on the phone, then you will get 3G network on one card and 2G network on the other card. To use 3G on the sim card that you want, change the other sim card to 2G mode.
My Duos does not support 850mhz 3g apparently.....told by the Spark Shop in my town....therefore will not operate with their network. It's ok on 2 degrees network and I think Vodophone.
Can't find any solution to this problem. They did say it would work in the main NZ centers, like Auckland or Wellington.
Not much good to me in the country.
Can this be changed or do I buy a different phone, or change the network?
TNX
