Help Problem syncing Facebook contacts
tiring_day
Member
Hi
When I try to sync Facebook contacts either by adding the accounts on the Contacts screen or by going to "Accounts & sync" Facebook appears as an option but when pressed just goes back to accounts without adding the contacts.
I have tried re-installing Facebook, changed the email accounts associated with the facebook account to her gmail one (just in case). Has anyone managed to do this or had a problem like this they solved?
Thanks in advance
Steve
Try the simple thing first....
1. Remove the account from the Settings->Accounts & Sync
2. Re-add it (it will ask you to login with the e-mail address and password associated with your Facebook Account).
3. Then go to your "People" app and do a refresh using the icon in the row across the bottom (the one with the refresh circle on it).
That worked for me...at least once.
If that doesn't work for you...next try changing the frequency with which your phone syncs with Facebook...see HERE.
Also, THIS GUY says forcing individual Facebook contacts to synch on a one-by-one basis sometimes helps.
Finally, are you using a Facebook App on your phone (vs. just the mobile site)? If so, which one are you using (e.g., official one, v1.5.0 is most current)?
Hi Astrobill
Thanks for the reply, I totally managed to miss it until now. Howver none of the above helps as I am unable to add Facebook to the accounts and Sync at all so unable to remove and re-add. Yes the latest facebook is on the phone and have even tried removing and re-adding it. Is just a very weird fault as when I go to add the account it gives Facebook as an option but when I make the selection it just goes back to Accounts and Sync page.
It's not a big deal as my wife is happy with the way it is working as I sync'd contact photos with something I cant remember the name of but would like to get it to work.
Thanks
Steve
I'm having the same problem. And others. When I try to add Facebook as an account for my contacts to sync with, it won't let me. The option is there, I click it/touch it, but nothing happens. Blah.
