haree
The Problem is : my Phone is hanging when i use a 8gb SD card and flash a cooked rom
What card do i have : SanDisk 8GB SDHC card.
No problem with the card i have tested it the card is OK
What have i tried
1. 1GB ext3 32mb swap
2. 512Ext3 32mb swap
3. 512Ext3 no swap
every time i flash a cooked ROM with apps2sd the phone hangs
for example after flashing the Rom i go to the clock to set my alarm the phone just hangs
cant do anything need to pull out the battery and put it back in the phone and re start the phone
this happens for any application i try to open after flashing the cooked rom
i have no problem flashing the cooked rom with my existing 4GB
i also have no problem using the 8GB with stock rom or Nand backup
can any one kindly give me a solution to use the 8GB with a cooked ROM which has apps 2sd
Id be most obliged if any one an give a solution for my Problem
thanks in advance
What have i tried
3. 512Ext3 no swap
thanks in advance
