Since upgrading to jellybean there seems to be a problem with my autocorrect/spellcheck. When using 3x4 keyboard 4 3 5 5 6 use to spell hello, now it spells gdjjm with the option to select hello, which is a massive pain in the ass to do everytime. If I use continuous input (aka swipe type) it seems to work. If I switch to qwerty keyboard and make a mistake it doesn't automatically change to the correct spelling, although it gives me the option to select it. I've searched quite a bit with no luck and even called Samsung but can't seem to find a solution. Is there a way I can downgrade to ics and then upgrade to jellybean again? This is my last ditch attempt, Samsung's idea was to basically wait for next update and hope for the best...
