Help Problem with chinese language input
meetfdc
i only find english and spanish,..can anyone tell me how to get chinese language input method??
thanks...................:)
You need to search the market for a Chinese input keyboard. Then, once it's installed, tap and hold on any input field to change which input you're using (swype > android default > other keyboard). I had to do the same thing to get Japanese input; that keyboard is called Simeji, and it's very good. Hopefully there's one as good for Chinese.
Google has their own keyboard for chinese input in the market. It's called Google Pinyin IME
chart
